not sure what you mean ?
I got this from token extractor
Devices found for server “de”:
MAC: B0:4A:xxxxxxx
IP: 192.168.1.146
TOKEN: 7a375xxxxxxxxxxxxxxxxxxxxxx
MODEL: roborock.vacuum.a15
My lovelace code is:
- type: custom:xiaomi-vacuum-map-card
title: Mapping
view_layout:
grid-area: map
card_mod:
class: header
language: GB
entity: vacuum.roborock_vacuum_a15
map_source:
camera: camera.xiaomi_cloud_map_extractor
calibration_source:
camera: true
my configuration.yaml is:
camera:
platform: xiaomi_cloud_map_extractor
host: 192.168.1.60
token: 7a375xxxxxxxxxxxxxxxxxxxxxxxxxxxx
username: [email protected]
password: xxxxxxxxxxxxxxxxxxxxxx
draw: [‘all’]
attributes:
host ip of 192.168.1.60 is my homeassistant server/install
IP of 192.168.1.146 is the IP of the vacuum
i dont know if this is some type of conflict or probelm
but in my configuration.yaml i have the arlo HACS mod installed which uses this code
camera:
platform: aarlo
ffmpeg_arguments: ‘-pred 1 -q:v 2’
platform: aarlo
monitored_conditions:
total_cameras
last_capture
recent_activity
captured_today
battery_level
signal_strength
temperature
humidity
air_quality
I noticed the camera code is the same?
camera:
host: 192.168.1.60
would the word “camera:” be causing a problem ?
ok so i disabled the xiamoi plugins and removed the “camera” code from the config
now my arlo cameras are working again so it must be casuing a conflict having the same “camera” name
Can i change this to camera1 or something?
3_14
(Piotr Machowski)
May 16, 2022, 10:18am
673
Uhhhhhh you should use IP of the vacuum, not HA server
You have to use these two entries in the same camera
section
camera:
- platform: aarlo
- platform: xiaomi_cloud_map_extractor
thank you it was the double camera entry casuing the issue!
great job as always, thnx for supporting us!
foxy
(Michelle)
June 19, 2022, 4:17pm
677
Did you ever figure this out? I’m getting the same error.
3_14
(Piotr Machowski)
June 19, 2022, 4:29pm
678
It should be fixed for viomi.vacuum.v18
. Which vacuum model do you have?
RaA11
June 19, 2022, 4:39pm
679
There’s any option to rotate the map? (I have rotated the map on the xiomi mobile app).
Thank You,
3_14
(Piotr Machowski)
June 19, 2022, 6:08pm
682
force_api: roidmi
should solve your problem
RaA11
June 19, 2022, 6:47pm
683
@3_14 I dont know were to put the “rotate: 270” line
entity: vacuum.roborock_s7
map_source:
calibration_source:
camera: true
map_modes:
- template: vacuum_clean_zone
- template: vacuum_clean_segment
predefined_selections:
- id: 18
label:
text: 4
x: 26200
'y': 29300
offset_y: 35
icon:
x: 26200
'y': 29300
- id: 17
label:
text: 2
x: 30025
'y': 26825
offset_y: 35
icon:
x: 30025
'y': 26825
- id: 19
label:
text: 3
x: 27300
'y': 27150
offset_y: 35
icon:
x: 27300
'y': 27150
- id: 20
label:
text: 1
x: 29575
'y': 35125
offset_y: 35
icon:
x: 29575
'y': 35125
- id: 16
label:
text: מטבח
x: 25575
'y': 34850
offset_y: 35
icon:
x: 25575
'y': 34850
- template: vacuum_follow_path
- template: vacuum_goto
language: he
two_finger_pan: true
vacuum_platform: default
title: ''
map_locked: true
rotate: 270
3_14
(Piotr Machowski)
June 19, 2022, 7:03pm
684
In Map Extractor’s config
foxy
(Michelle)
June 19, 2022, 11:48pm
686
Thanks, that fixed the issue. Glad I asked because I obviously wasn’t going to figure that one out!
I appreciate you taking your time to solve this for me.
Andre_Col
(LightOn)
June 30, 2022, 11:52am
687
will the xiaomi ijai.vacuum.v3 also be integrated? I have model vacuum mop 2 pro and the integration shows me, that this model is not supported. It this integration planed?
Thank you,
3_14
(Piotr Machowski)
June 30, 2022, 12:19pm
688
It’s not planned at this moment, but I’m willing to help anyone that will try to implement it.
Related issue:
opened 06:03AM - 14 Dec 21 UTC
enhancement
new platform
![image](https://user-images.githubusercontent.com/55863741/145942154-0282ada5-9… 314-4c67-9ade-6e9138c99926.png)
Hi, i have an error when the vacuum finished cleaning. i have two vacuums one roborock s7 and one roborock s7 maxV ultra. i do believe this error now came from S7. everything works ok but this error is displayed in the logs all the time when its finishing the clean.
STATE not supported: Definition missing for state 26, state_code: 26
STATE not supported: Definition missing for state 23, state_code: 23
