I just updated. UI configuration is very easy. Thank you.
But Roborock S6 map wont be load. Do I need continue to use “Robrock map reloader” blueprint / automation?
No, the blueprint won’t work with v3 version - it should not be needed at all. Does the map work in Xiaomi Home? Could you please also share logs from HA?
I am not familiar with logging. But map works in android Roborock app.
This gives you some info?
Logger: custom_components.xiaomi_cloud_map_extractor.connector.vacuums.base.vacuum_base
Source: custom_components/xiaomi_cloud_map_extractor/connector/vacuums/base/vacuum_base.py:83
integration: Xiaomi Cloud Map Extractor (documentation, issues)
First occurred: 15:02:45 (4 occurrences)
Last logged: 15:04:40
FailedMapDownloadException
Wait a second…
This integration doesn’t work when you use Roborock app.
So i have to log out in app or delete device inside app?
Your vacuum has to be added to Xiaomi Home integration for Map Extractor to work.
But if Roborock app works for you then you should just use the built-in Roborock integration
Sorry, I got confused. I actually use the Xiaomi Home app and not Roborock.
Only map wont load. Other functions works fine.
Ok, so the map works in Xiaomi Home, correct? Can you enable debug logging and check HA logs again?
Yes in Xiamo Home it works.
I enabled debug logging and when I check logs there was those errors. I don’t understand this logging because when I watch other people logs then there is more detailed info
Logger: py.warnings
Source: components/xiaomi_miio/init.py:12
First occurred: 16:36:32 (1 occurrences)
Last logged: 16:36:32
/usr/local/lib/python3.13/site-packages/miio/miot_device.py:23: FutureWarning: functools.partial will be a method descriptor in future Python versions; wrap it in enum.member() if you want to preserve the old behavior Bool = partial(_str2bool)
Logger: homeassistant.bootstrap
Source: bootstrap.py:756
First occurred: 16:37:31 (1 occurrences)
Last logged: 16:37:31
Waiting on integrations to complete setup: {(‘xiaomi_cloud_map_extractor’, ‘01JKZ1YKR0VGD0WAFTFE0FJF22’): 1037941.986112205}
First occurred: 16:38:03 (3 occurrences)
Last logged: 16:38:52
Yeah, it would be better to look at the log file directly.
It is available in /config/home-assistant.log
I made Roborock robot vacuum restart few hours ago and then after restart no map at all.
Now i turned Roborock robot vacuum off and about 1 hour later turned on again. And now i get partial map.
Here are log after i turn this on after 1 hours being off.
Logger: custom_components.xiaomi_cloud_map_extractor.coordinator
Source: helpers/update_coordinator.py:380
First occurred: 18:54:20 (282 occurrences)
Last logged: 20:04:35
Unexpected error fetching xiaomi_cloud_map_extractor data
File “/config/custom_components/xiaomi_cloud_map_extractor/connector/vacuums/vacuum_roborock.py”, line 54, in should_update_map
code = self._vacuum.status().state_code
File “/usr/local/lib/python3.13/site-packages/miio/click_common.py”, line 184, in _wrap
return func(self, *args, **kwargs)
File “/usr/local/lib/python3.13/site-packages/miio/integrations/vacuum/roborock/vacuum.py”, line 406, in status
return VacuumStatus(self.send(“get_status”)[0])
File “/usr/local/lib/python3.13/site-packages/miio/device.py”, line 107, in send
return self._protocol.send(
command, parameters, retry_count, extra_parameters=extra_parameters
File “/usr/local/lib/python3.13/site-packages/miio/miioprotocol.py”, line 161, in send
self.send_handshake()
File “/usr/local/lib/python3.13/site-packages/miio/miioprotocol.py”, line 74, in send_handshake
raise DeviceException(“Unable to discover the device %s” % self.ip)
miio.exceptions.DeviceException: Unable to discover the device 192.168.25.171
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 380, in _async_refresh
self.data = await self._async_update_data()
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 281, in _async_update_data
return await self.update_method()
File “/config/custom_components/xiaomi_cloud_map_extractor/coordinator.py”, line 35, in update_data
return await self.connector.get_data()
File “/config/custom_components/xiaomi_cloud_map_extractor/connector/init.py”, line 63, in get_data
if self._should_get_map():
File “/config/custom_components/xiaomi_cloud_map_extractor/connector/init.py”, line 112, in _should_get_map
return self._map_cache is None or self._vacuum_connector is None or self._vacuum_connector.should_update_map
File “/config/custom_components/xiaomi_cloud_map_extractor/connector/vacuums/vacuum_roborock.py”, line 79, in should_update_map
if “token” in de:
TypeError: argument of type ‘DeviceException’ is not iterable
Ok, I have to handle this exception more gracefully
Regarding the map:
It looks a bit wild, does it still look this way? If so, can you download diagnostic data from the integration and send it to me in a private message?
Oh i dont know what just happened. I reinstalled xiaomi map reloder and then map was all good.
When I submitted my image size parameters then map goes wild like previously I showed.
Scale 1 worked correctly. But 2 and above goes crazy and then I tried scale 10 and suddenly It trys to reconnect HA.
I just don’t know what happed but mini PC where HA is installed turns on but cant get connections to HA.
OMG
You shouldn’t really go above 4 with image scale, unless your map is really microscopical. It drastically increases resources usage.
Does dreame.vacuum.p2140p supported? I see dreame.vacuum.p2140 in supported devices and I don’t know if it’s same. For me (for dreame.vacuum.p2140p) this integration doesn’t work. I have this error:
2025-03-01 12:11:25.205 ERROR (MainThread) [homeassistant.helpers.entity] Update for camera.xiaomi_cloud_map_extractor fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 960, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1320, in async_device_update
await hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
File "/config/custom_components/xiaomi_cloud_map_extractor/camera.py", line 291, in update
self._handle_map_data(self._map_name)
File "/config/custom_components/xiaomi_cloud_map_extractor/camera.py", line 362, in _handle_map_data
map_data, map_stored = self._device.get_map(map_name, self._colors, self._drawables, self._texts,
self._sizes, self._image_config, store_map_path)
File "/config/custom_components/xiaomi_cloud_map_extractor/common/vacuum.py", line 36, in get_map
map_data = self.decode_map(response, colors, drawables, texts, sizes, image_config)
File "/config/custom_components/xiaomi_cloud_map_extractor/dreame/vacuum.py", line 24, in decode_map
return MapDataParserDreame.decode_map(raw_map_string, colors, drawables, texts, sizes, image_config)
File "/config/custom_components/xiaomi_cloud_map_extractor/dreame/map_data_parser.py", line 51, in decode_map
unzipped = zlib.decompress(base64.decodebytes(raw_map_string.encode("utf8")))
zlib.error: Error -3 while decompressing data: incorrect header check
Here is raw map data:
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
The configuration:
camera:
- platform: xiaomi_cloud_map_extractor
host: 192.168.xxx.xxx
token: xxxxxxxxxxxxxxxxxxx
username: xxxxxxxxxxxxxx
password: xxxxxxxxxxxxxxxx
country: ru
draw: ['all']
attributes:
- calibration_points
store_map_raw: true
force_api: dreame # same result with and without this option
I hope this can help to fix support for this device
Can you try the latest alpha version of the integration?
