UI has been added in the alpha version
Sorry, was this for how to get my vacuum added? I don’t quite understand what to do.
No, this was for @mandraker81
You just have to install the latest alpha and check if it works.
It appears to not like my timezone (see below). Using latest Alpha.
Logs
Logger: aiohttp.server
Source: /usr/local/lib/python3.14/site-packages/aiohttp/web_protocol.py:488
First occurred: 3:04:17 PM (7 occurrences)
Last logged: 3:04:20 PM
Error handling request from 192.168.1.178
File "/usr/local/lib/python3.14/site-packages/aiohttp/web_protocol.py", line 517, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.14/site-packages/aiohttp/web_app.py", line 569, in _handle
return await handler(request)
File "/usr/local/lib/python3.14/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 87, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 90, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 295, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 41, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 89, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 83, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 234, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
return await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 121, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 336, in async_configure
result = await self._async_configure(flow_id, user_input)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1536, in _async_configure
return await super()._async_configure(flow_id, user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 383, in _async_configure
result = await self._async_handle_step(
flow, cur_step["step_id"], user_input
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 483, in _async_handle_step
result: _FlowResultT = await getattr(flow, method)(user_input)
File "/config/custom_components/xiaomi_cloud_map_extractor/config_flow.py", line 152, in async_step_auth_credentials
self._connector = XiaomiCloudConnector(session_creator)
File "/config/custom_components/xiaomi_cloud_map_extractor/connector/xiaomi_cloud/connector.py", line 140, in __init__
timezone = datetime.datetime.now(tzlocal.get_localzone()).strftime('%z')
File "/usr/local/lib/python3.14/site-packages/tzlocal/unix.py", line 237, in get_localzone
_cache_tz = _get_localzone()
File "/usr/local/lib/python3.14/site-packages/tzlocal/unix.py", line 190, in _get_localzone
tzenv = utils._tz_from_env()
File "/usr/local/lib/python3.14/site-packages/tzlocal/utils.py", line 105, in _tz_from_env
raise zoneinfo.ZoneInfoNotFoundError(
...<2 lines>...
) from None
zoneinfo._common.ZoneInfoNotFoundError: 'tzlocal() does not support non-zoneinfo timezones like Auckland. \nPlease use a timezone in the form of Continent/City'
I kept running into these problems too so ended up building something for it. Sign in with your Mi account and you get the floor plan as a camera entity and a Lovelace card that updates live. If you'd rather skip the account, IP and token still gets you full local control, just no map.
Why use this instead of Xiaomi Home - Home Assistant ? Definitely interested if it will get me per-room cleaning and a working map.
Extra bonus (may be impossible), I'd love to define its rooms from within HA as in the app they frequently... delete themselves.
