I’m trying to use the rotate cube action to turn a led strip on if turning to the right and off if turning to the left. To do that I thought I’d use a service_template so I create the following:
This is not working I get this error in syslog: [homeassistant.helpers.service] Error rendering service name template: UndefinedError: 'light' is undefined
I think this will work for you and if you change int + 255 and int - 255 to something lower like int + 50 and int - 50 this will brighten and dim your led strip, should work let me know.
You’ve put brackets round the light services, they need to be removed.
So the if lines have brackets, then the service doesn’t, what you’re saying is if the stuff inside the bracket is true, do the service outside the bracket, if it’s false skip to the next bracket.
At the moment the next bracket doesn’t contain an if it contains a light, hence the error.
Also, the brightness can’t be defined how you’ve defined it, and you’ve declared service_template: twice.
