jeppper
(Jeppper)
November 29, 2020, 7:28pm
1
What is the correct procedure for implementing the Xiaomi cube into Home Assistant via zigbee2mqtt?
I have tried this from the guide https://www.zigbee2mqtt.io/devices/MFKZQ01LM.html
Pairing with z2m is okay.
- platform: "mqtt"
state_topic: "zigbee2mqtt/xiaomi_cube"
availability_topic: "zigbee2mqtt/bridge/state"
value_template: "{{ value_json.action }}"
but i guessed its outdated and tried to change it to:
- platform: "mqtt"
json_attributes_topic: "zigbee2mqtt/xiaomi_cube"
Anyway nothing happens in HA. State is always “unknown”
In configuration.yaml in z2m I simply have:
‘0x00158d00010b28a2’:
friendly_name: xiaomi_cube
Must something be added?
jeppper
(Jeppper)
December 3, 2020, 7:21pm
2
No one has implemented the Cube in HA from zigbee2mqtt?
caroga
(Roberto)
April 8, 2021, 11:18am
3
I am wondering if you have got this working already, cause I’m currently at the same point where HA is throwing rendering errors like
homeassistant_1 | 2021-04-08 13:18:19 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'action_angle' when rendering '{{ value_json.action_angle }}'
homeassistant_1 | 2021-04-08 13:18:19 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'action_from_side' when rendering '{{ value_json.action_from_side }}'
homeassistant_1 | 2021-04-08 13:18:19 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'action_side' when rendering '{{ value_json.action_side }}'
homeassistant_1 | 2021-04-08 13:18:19 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'action_to_side' when rendering '{{ value_json.action_to_side }}'
jeppper
(Jeppper)
April 8, 2021, 2:37pm
4
Hi.
Yes it is working and I still use this for integration:
- platform: "mqtt"
And this as an example for automation:
- alias: Sonos bio PLAY when Cube FLIP 90
- platform: mqtt
topic: 'zigbee2mqtt/xiaomi_cube'
condition:
- condition: template
value_template: '{{ "flip90" == trigger.payload_json.action or "flip180" == trigger.payload_json.action or "tap" == trigger.payload_json.action }}'
- service: media_player.volume_set
entity_id: media_player.bio
volume_level: 0.15
- service: media_player.select_source
data_template:
source: '{{ states.input_select.select_radio_ihc_dag.state }}'
- service: media_player.media_play
bachoo786
(Bachoo786)
April 21, 2021, 2:48pm
5
I have got the same issue with Tuya TRVs. Is anyone experiencing the same?
