Hello after installed Xiaomi MIIO Gateway3 and added it in Integrations, devices and entities are not added.
Product information:
Xiaomi Gateway 3 ZNDMWG03LM on original firmware.1.4.6_0043
After I go to read los and this is the information:
I did some more digging. Gateway 3 hasn’t been developed yet in HA to support Bluetooth devices. Gateway 3 is still very much in development. I wouldn’t recommend buying one.
I think the guy I bought it off on ebay who was selling as new but I could see signs of it being used probably resold it after he found out it is pretty useless in HA.
If you are not asking about ZHA then suggest not posted the question in the ZHA or Zigbee sections.
PS: Yes you can use the same hardware with different firmware for Bluetooth but then you will need to use a different integration for Home Assistant that is not for Zigbee, as Zigbee is only Zigbee protocols.
Sorry about that! I was just following up to the post by @Three and hadn’t noticed we were in the ZHA section. This entire thread might fit better elsewhere.
