I just installed the xiaomi_aqara component with the gateway, everything showed up as expected, including the water leak sensor. However, the gateway light cannot be turned on via HA. Is this a known issue or anyone know of a fix?
Check the log.
Is the key correct?
The log says I have an invalid key… as it turns out I need to enter the key using capital letters instead of lower case. Thanks for the help!
