Xiaomi lights
Stumbled upon xiaomi lights component.
Looking at the docs
Xiaomi Light
The xiaomi light platform allows you to get data from your Xiaomi lights.
The requirement is that you have setup Xiaomi.
And a little bit lost - which lights are supported?
You a right the documentation is not very good in this point. You found this one:
It’s part of the xiaomi gateway and this component controls the internal light of the xiaomi gateway. There are no additional devices support. Since HA 0.53 there is a new light component for “Xiaomi Philips Lights” and my be you are looking for the yeelights component to control a yeelight?
https://home-assistant.io/components/light.xiaomi_philipslight/
I just prepared a PR to fix the documentation:
https://github.com/home-assistant/home-assistant.github.io/pull/3338
