I see that there are no buttons to increase/decrease the values or readings of temperature and humidity. But there are several ways I know how to calibrate the humidity – salt and boveda.
Is there a way to +/- values to whatever the current reading on the LCD screen?
Say if my sensor reading is 77%, if my calibration shows that the sensor is 2% high, how do I subtract 2% to the value shown in HA?
If you want to adjust the reading that HASS uses, you can also use a custom sensor. Here’s one of my mqtt sensors where I’m adjusting the humidity reading by -1%.
