No. It needs to be paired with the xiaomi gateway.
Whatâs the issue in detail? The values of the mi home app and home assistant doesnât match?
In this case ha report 0 in load PowerâŚ
so which code to use for wifi plugs? please help. thanks
how to get the the token?
@syssi, I just updated to 55.0 and HA was throwing errors about ATTRIBUTE.CURRENT is not defined and no WiFi plugs would show up.
I went through the xiaomi_plug.py doc and commented out the references to ATTRIBUTE.CURRENT and now the component is working again as it should.
ATTR_POWER = 'power'
ATTR_TEMPERATURE = 'temperature'
#ATTR_CURRENT = 'current'
SUCCESS = ['ok']
self._plug = plug
self._state = None
self._state_attrs = {
ATTR_TEMPERATURE: None,
# ATTR_CURRENT: None
self._skip_update = False
self._state = state.is_on
ATTR_TEMPERATURE: state.temperature,
# ATTR_CURRENT: state.current,
It looks like you should update the custom component. This issue was fixed recently.
Thatâs odd, I was on 54.0 and had no issue, it only occurred after upgrading to 55.0
hi can you help me
where i put xiaomi_plug.py file in pi3 so i can work with my Xiaomi WiFi Plug?
Just create a folder called âcustom_componentsâ at the same directory as your configuration.yaml. In my case it looks like this:
/home/homeassistant/.homeassistant/custom_components/switch/xiaomi_plug.py
@flyguy Do you still use the Chuang Mi Plug V1 with the USB port? Could you check something to improve the Home Assistant support?
Canât get the token no rooted android phone
Could you try to ask the plug for the property temperature? Does the device provide an internal temperature?
cp. Plug with USB port compatibility? ¡ Issue #5 ¡ syssi/xiaomiplug ¡ GitHub
Whatâs the output of
mirobo --ip 10.x.x.x --token a3d7fxxx get_prop '["on","usb_on", "temperature"]'
Some good news! The xiaomiplug (official called switch.xiaomi_miio!) will be part of HA 0.56. In addition I have created a pull request for the xiaomi_airpurifier (in future called fan.xiaomi_miio): https://github.com/home-assistant/home-assistant/pull/9837
The xiaomiplug (switch.xiaomi_miio) gets a few recently added features soon. Itâs part of this pull request: https://github.com/home-assistant/home-assistant/pull/9836
Hey congrats dude! Still havenât gotten my purifier⌠But one of these days!
If it is included in HA 0.55.
How to enable it to discover my plugs and power strips.
Itâs not working.
I was wrong. It will be released with version 0.56.
