Xiaomi Mijia bedside lamp / wifi
https://www.gearbest.com/smart-lighting/pp_1032313.html
Is this lamp compatible with HA and can be fully controlled with it? Will this lamp require internet connection to function, or can it be safely blocked from internet?
Is there any other similar lamp you could recommend which works well with HA?
The device isn’t supported yet (light.xiaomi_miio). If somebody has access to the device it could be integrated easily probably. Most xiaomi devices works fine without internet after the provisioning.
The device is supported and can be used withour internet. It support a lan mode for developers
https://home-assistant.io/components/light.yeelight/
Oh, cool! The manual of the component mentions the supported devices at the bottom: https://home-assistant.io/components/light.yeelight/
Great, then I’ll get myself one of those :slight_smile:
hi,
what about the BLE gateway this light provide ?
As far as I understood some new yeelight bulbs are not wifi anymore but bluetooth mesh (a kind of zwave but for bluetooth) and this light can control other bluetooth devices.
Can this be controled bw HA ?
Or does HA only control the light and not the bluetooth devices that are on the light ?
I have the same question.
