Hi everyone.
I had one of these xiaomi universal remote devices and it worked great so I got a second one.
Got the token and settings needed for it and then copied the installation of the current one.
Nothing
System doesn’t throw out an error and as far as HA thinks it sent the signal, but the device does not transmit anything, LED doesn’t even blink.
Troubleshooting:
From the mi home app I tested device and device is working correctly.
Hashed out config from the previous unit to make sure there wasn’t some sort of conflict.
Double-checked IP address and token are correct
Same results
Debug logs of working unit is the same as not working unit.
Any thoughts or suggestions for me to try?
