Xiaomi Sensors and Flashing Icon / Message
Hey all,
I was just wondering if it is possible to create som kind of a flashing icon, or a message pop-up, on the Home Assistant dashboard, if one of my Xiaomi motions sensors get triggered.
I got this info screen on my wall at home, but only the icon change and stays static until the state changes back. It would be nice if the icon could flash during the time. Another solution could be to create a pop-up, that shows a text with a warning and then disappears when the state changes to off.
Does any of you have a nice approach?
Another one; if the above is somehow possible, is it then also possible to open up another window (like a surveillance cam), just the way it would open if you press it manually?
Thanks…
There are no pop-ups as such but there are persitent notifications you could bring up and dismiss:
You could put your camera in a group and control this group visibility:
https://www.home-assistant.io/docs/configuration/group_visibility/
