Xiaomi smart home hub and sensors
Hi all,
First of all, thanks for this great forum and community. I didn’t found any “welcome” section as usual in other communities.
I’m starting in this smart home world and I have Hass.io in a Rpi2. By now, I only have one multisensor and a couple of webcams. I also integrated misc stuff like plex, spotify, etc.
My question is about Xiaomi smart home devices. I would like to have all smart devices with encryption support, I would prefer avoid using cleartext communications.
Anyone knows if xiaomi sensors are using encryption when linking to hass?
In case I use all xiaomi smart home hub, they are using encryption?
Thanks,
Hey welcome to the community!
I don’t know a lot about security/encryption. But as far as i know, you need the hub/gateway to make use of the xiaomi sensors and switches in Home-Assistant. I think i read somewhere that the sensors can be read by any device on the network. But if you want to control something like a light you need to have a key added to your HA configuration in order to be able to control it. This key can be obtained by enabeling devloper mode on the gateway.
The Xiaomi gateway and sensors use a slightly proprietary flavour of zigbee.
This guy explains the encryption used.
(french but google translate works v well)
Some of the comms is not encrypted (e.g. request for sensor pairing)
Usual comms is encrypted based on the gateways unique key.
