Xiaomi smartmi smart humidifier 2 integration into home assisant
Maybe a stupid question, But which integration do i have to use to get the smart humidifier 2 into my HA installation? Do i need additional hardware for this?
I see a couple of official integrations in HA for xiaomi and a couple of hacs things, But which one do i use?
I prefer a local connection if possible.
Did you manage to find a solution?
Hi Eric,
Yes, you have to connect the humidifier to the Xiaomi Home app first.
Then i used the Xiaomi Miio integration in HA to get the data fro the cloud.
The device is working fine now is HA.
Thanks. I want to try this humidifier but I “prefer” local connection (did you figure out any solution) and need to know if the tank is empty to get notified.
Can you please tell if this is available ?
Thank you very much
Late suggestion. Maybe it helps somebody else.
You can get the dumb version.
That one has only a rotational button hardware.
Let it ON with the wanted level set and use a smart plug to turn it on.
can you share your configuration ?
Currently I can only switch it on and off.
I would like to set the target humidity and the mode (low, mid, …).
I was able to configure the attribute target_level but I am not sure how to set via UI.
Hope you can help me
Thanks, Oliver
If you do not want to use the Cloud, you must obtain a Token using this guide.
