Hi. i just xiaomi smoke detector and xiaomi hub. the thing is, it does not trigger an alarm sound in your phone when it detect smoke. is there a way to make HA execute some kind of alarm ? Thanks. Refael.
I changed my Xiaomi Smoke alarm to zigbee2mqtt. 2 more arrived today and I will add to the group
I then made an automation when triggered
- alias: Fire alarm trigger on
platform: state
entity_id: binary_sensor.0x00158d000276fb05_smoke # down stairs
to: 'on'
- service: script.turn_on
entity_id: script.fire_alarm
- alias: Fire alarm trigger off
platform: state
to: 'off'
- service: script.turn_off
entity_id: script.fire_alarm, script.fire_alarm_loop
with a script that broadcasts an alarm on Google Home
alias: Fire Alarm
sequence:
- service: media_player.volume_set
entity_id: media_player.kitchen_speaker, media_player.googlehome1023
volume_level: '0.90'
- service: tts.google_say
message: 'Fire Alarm, Evacuate'
- delay:
seconds: 2
- service: media_player.play_media
media_content_id: https://xxxxxxxxxxxx/local/submarine_diving_alarm.mp3
media_content_type: 'audio/mp3'
- delay:
seconds: 1
entity_id: script.fire_alarm_loop
alias: Fire Alarm loop
sequence:
- delay:
# time for flash light off
seconds: 2
I like how you did the loop. Saving that one for later
Thanks a lot ColonelFlag.
Is there something you can go on your phone also?
Refael
i also tried this
media_content_id: /local/sounds/submarine-diving-alarm-daniel_simon.mp3
hi, I have an automation with a call to my home alarm and notify to my ios device, works fine
I am using ColonelFlagg’s scripts but getting some errors.
See my script below:
tts_notification:
alias: Fire Alarm
sequence:
entity_id: media_player.office, media_player.living_room, media_player.kitchen, media_player.hallway
- delay:
seconds: 2
media_content_id: https://xxxxxxxx:8123/local/security_breach.mp3
- delay:
seconds: 1
sequence:
- delay:
seconds: 2
The config validation passes but I see the following errors in the logs:
INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /config
ERROR:homeassistant.util.yaml:YAML file /config/scripts.yaml contains duplicate key "alias". Check lines 1 and 24.
ERROR:homeassistant.util.yaml:YAML file /config/scripts.yaml contains duplicate key "sequence". Check lines 2 and 25
Please help!
The formatting is probably wrong, try this:
tts_notification:
alias: Fire Alarm
sequence:
entity_id: (i'd personally set up a group in groups e.g. group.mediaplayers)
and go on from here . I am not entirely sure if your script will work though, but I haven’t played around much with it so I wouldn’t know. But this formatting works for me.
Is it possible to communicate with the smoke alarm via zigbee2mqtt to change the settings? Eg. Sensitivity. AFAIK it has 3 sensitivity settings.
Yes, you can.
You need to publish the sensitivity to the detector.
More info in zigbee2mqtt site.
