Xiaomi Thermostat not updating data
I bought this of Gearbest https://www.gearbest.com/robot-vacuum-accessories/pp_1306883.html?wid=1433363 with the hope I can connect it to my HA to control smart switches depending on temps.
I saw that you can add the sensor by grabbing the MAC address by connecting to a phone and using an app to get the MAC. This worked great and I now see the device on home assistant but the values aren’t updating.
It’s working in the MI Home app so i know the connection is with the gateway I have but it’s not getting through to HA. Is there something i’m doing wrong?
Hi i thought i would add my config to this thread to see if anyone can help.
  - platform: mitemp_bt
    mac: 4C65A8DCBEA6
    force_update: true
    median: 1
    monitored_conditions:
      - temperature
      - humidity
      - battery
I have changed force update to be true but still no joy as of yet!
as you can see it’s discovered it
I have the Xiaomi Thermostat Accuracy Temperature Humidity Monitor
which doesn’t look to be supported.
i did post about why it isn’t working which you can find here.
try the mac address with colons as per https://www.home-assistant.io/components/mitemp_bt/
Yep thanks the mac needed to be with the : init.
Annoying as the Xiaomi gateway didn’t want them in so got confused.
Thanks again Jon.
