Xiaomi TV mitv-mssp2 IR power on / off code command vs Broadlink
I have a xiaomi mitv-mssp2 television and I want to be able to turn it on through home assistant - Broadlink RM4 mini
I confirmed that I can turn the TV on and off using the Broadlink app, but through Home Assistant I can only turn it off using the command:
JgA0ACMRFhEWLRYtFhEWLRYRFi0WERUuFi0WAAFTIhEWERYtFi0WERYtFhEVLhYRFS4VLhYADQUAAAAA
Does anyone have the command to turn on the TV?
Thank you.
In the meantime I got another Broadlink (RM pro+) and managed to map the Broadlink RM4 mini command to the RM pro+ via HomeAssistant.
If anyone needs:
Xiaomi TV mitv-mssp2 IR power on / off code command:
JgA0ACMVEhQTMRQxExQTMRMUEzEUFBIyEzETAAFiIBQUFBMxEzETFBMxFBQTMRIVEzETMRQADQUAAAAA
Thank you.
