Hi all,
i bought 2 Xiaomi WiFi Plugs about two months ago because they were a little cheaper than the Zigbee version.
They connect to WiFi directly and don’t require the Gateway which i still also have because all my other Xiaomi stuff needs it.
Now, the WiFi plugs both randomly disconnect from hass.io. As i can see from the hass.io logs they disconnect from 3 times per week up to 10 times per day.
Both plugs are within 5m/16ft range of my Unifi AP AC LR.
My Unifi Controller tells me that their “WiFi experience” is between 3%-15% which is obviously terrible but their signal strength is between -50db and -45db.
Even more surprising is the fact, that according to the Unifi Controller, both plugs have never disconnected since i first set them up, they have been connected to my WiFi for 2 months straight.
So is this a bug within hass.io or are the WiFi plugs just garbage?
Has anyone else experienced the same problems?
