Xiaomi Zone Cleaning automation rule problem
Hi guys,
I have some difficulties with setting app zone cleaning with Xiaomi Robot Vacuum.
I want to use select list and automation rule instead of scripts.
This is the automation I’ve got setup
- alias: 'Xiaomi Vacuum Zone Cleaning'
  hide_entity: True
    platform: state
    entity_id: input_select.xiaomi_vacuum_cleaner_zone
  condition:
    condition: template
    value_template: '{{ trigger.to_state.state != "Select" }}'
    - service: vacuum.xiaomi_clean_zone
      data_template:
        zone: >
          {% if trigger.to_state.state == "Kitchen" %}
            [[34050, 27950, 35900, 29250]]
          {% elif trigger.to_state.state == "Living Room" %}
            [[31000, 24350, 37200, 27900]]
          {% elif trigger.to_state.state == "Hole Room" %}
            [[28000, 25900, 31000, 27500]]
          {% elif trigger.to_state.state == "Bedroom" %}
            [[25500, 25300, 28000, 26700]]
          {% else %}
          {% endif %}
        entity_id: vacuum.xiaomi_robot_vacuum_cleaner
        repeats: 2
Problem is that I’m getting error like this:
Error while executing automation automation.xiaomi_vacuum_zone_cleaning. Invalid data for call_service at pos 1: expected list for dictionary value @ data['zone']
Problem doesn’t occure if I’m not using if/else statement, but passing single parameter.
Thanks in advance
Do you need commas between zones?
FYI, opened Github issue because this looks like a bug to me: https://github.com/home-assistant/home-assistant/issues/23634
