blueprint:
name: XMPP Text Message Received
description: Handle received XMPP text messages with translation, dynamic filters, and TTS announcements.
domain: automation
input:
webhook_id:
description: The webhook ID for XMPP messages.
default: xmpp_inbound
media_player:
name: Media Player for TTS
description: Select the media player for TTS announcements.
selector:
entity:
domain: media_player
exclude_senders:
description: List of senders to exclude from TTS and popups. Defaults are pre-filled.
default:
- home-assistant
excluded_keywords:
description: List of keywords to exclude from TTS and popups. Defaults are pre-filled.
default:
- Prowlarr
- sessions
announcements_private:
name: Private Message Announcements
description: Default TTS announcements for private messages.
default:
- "Achtung, Achtung! {} hat eine Nachricht geschickt!"
- "{} hat geschrieben! Hört sich wichtig an!"
announcements_group:
name: Group Message Announcements
description: Default TTS announcements for group messages.
default:
- "Neue Nachricht von {} in der Gruppe {}!"
- "{} hat in der Gruppe {} geschrieben!"
- "Gruppennachricht von {} in {}!"
- "{} hat in der Gruppe {} geantwortet!"
- "Achtung, Gruppennachricht in {} von {}!"
custom_announcements_private:
name: Custom Private Message Announcements
description: Add custom templates for private message announcements.
default: []
custom_announcements_group:
name: Custom Group Message Announcements
description: Add custom templates for group message announcements.
default: []
- platform: webhook
webhook_id: !input webhook_id
condition:
- condition: template
value_template: >-
{{ trigger.json.image_url is not defined or trigger.json.image_url | length == 0 }}
- service: system_log.write
message: "Sender received: {{ trigger.json.sender }}"
level: info
- choose:
- conditions:
value_template: >-
{% set exclude_senders = input.exclude_senders %}
{% set excluded_keywords = input.excluded_keywords %}
{% set message = trigger.json.nachricht %}
{{ trigger.json.sender not in exclude_senders and not (excluded_keywords | select('in', message) | list) }}
sequence:
- service: browser_mod.popup
title: >
{% if trigger.json.is_groupchat %}
💬 Nachricht in der Gruppe {{ trigger.json.muc_title or trigger.json.muc_room }}
{% else %}
💬 Nachricht von {{ trigger.json.sender }}
{% endif %}
content:
type: vertical-stack
cards:
- type: markdown
content: |
**Originalnachricht:** {{ trigger.json.original_message }}
**Übersetzte Nachricht:** {{ trigger.json.nachricht }}
- service: input_text.set_value
entity_id: input_text.xmpp_last_sender
value: "{{ trigger.json.sender }}"
- service: tts.piper
cache: true
media_player_entity_id: !input media_player
message: >
{% set muc_title = trigger.json.muc_title or trigger.json.muc_room %}
{% set sender_name = trigger.json.sender %}
{% set all_private_announcements = input.announcements_private + input.custom_announcements_private %}
{% set all_group_announcements = input.announcements_group + input.custom_announcements_group %}
{% set announcement = (all_group_announcements | random).format(sender_name, muc_title) %}
{% else %}
{% set announcement = (all_private_announcements | random).format(sender_name) %}
{% endif %}
{{ announcement }} {{ trigger.json.nachricht }}.
mode: restart
Description will follow once the component is up and running. Only for testing at this moment.
