Yahoo Weather Configuration - Forecast
Am I missing something here? I cant seem to display the forecast in the next days.
my config (pretty much the same as the example on HA website)
- platform: yweather
  woeid: <redacted>
  forecast: 3
  monitored_conditions:
   - weather
   - temp_min
   - temp_max
and i dont see any 3 day forecast.
Help and thanks!
I’ve been wondering the same thing…have the same config as well and not seeing the forecast.
You will only see the forecast for day 3 using that set up. In order to see all three days, you’d need to create three separate sensors like this:
  forecast: 1
    - weather
    - temp_min
    - temp_max
  forecast: 2
    - weather
    - temp_min
    - temp_max
  forecast: 3
    - weather
    - temp_min
    - temp_max
It isn’t clear in the docs so I put in a PR to correct this and explain it better.
Thank you!
thank you @rpitera tested and they work great!
Cheers
No problem - BTW the PR for the updated docs was merged so this should help folks in the future.
