I got this lock set up using the app and through the app I put it in inclusion mode, I then added it to Home Assistant via ZWave JS. It shows up but there are no options. The only thing I see under Sensors is Last Seen and have nothing under controls. I don’t see any status, ability unlock the door, door open status…NADA. Any help would be appreciated.
Ok, finally got it figured out for anyone else running into the issue. During the inclusion you have to hit advanced options in the Zwave Inclusion screen and pick legacy secure as the option and then adpot the lock. Then you see all controls like if the door is locked or if it is open.
Hi, good you got it solved!
Please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
- this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
- this prevents that someone else steps in trying to help
Thanks for giving back to the community!
