Yale YRD256 Lock Unable To Clear Codes OpenZwave
Hey Everyone,
Ok I got this amazing lock for Christmas and I’ve been trying to figure this out. I can add codes to the lock all day long with no issue using either lock-manager or the ozw service. However, the lock never reports back to lock-manager that the code was added unless I restart the ozw container then everything that was programmed in the lock reports in and life is good for a moment.
So to rule out lock-mananger I’ve completely removed it from my install.
So thinking the lock was bad I ordered a replacement and now I have 2 locks at the moment and they both behave identical so now I know its not the locks.
So I can set the code
[20201231 3:48:27.857 UTC] [ozw.library] [debug]: Detail - Node: 130 Setting Encryption Flag on Message For Command Class COMMAND_CLASS_USER_CODE
[20201231 3:48:27.857 UTC] [ozw.library] [debug]: Detail - Node: 130 Queuing (Send) UserCodeCmd_Set (Node=130): 0x01, 0x0f, 0x00, 0x13, 0x82, 0x08, 0x63, 0x01, 0x01, 0x01, 0x31, 0x32, 0x33, 0x34, 0x25, 0x64, 0x4e
[20201231 3:48:27.858 UTC] [ozw.library] [debug]: Detail - Node: 130 Setting Encryption Flag on Message For Command Class COMMAND_CLASS_USER_CODE
[20201231 3:48:27.858 UTC] [ozw.library] [debug]: Detail - Node: 130 Queuing (Send) UserCodeCmd_Get (Node=130): 0x01, 0x0a, 0x00, 0x13, 0x82, 0x03, 0x63, 0x02, 0x01, 0x25, 0x65, 0x47
[20201231 3:48:27.859 UTC] [ozw.library] [info]: Info - Node: 130 Processing (Send) Nonce Request message (Callback ID=0x64, Expected Reply=0x13)
[20201231 3:48:27.859 UTC] [ozw.library] [info]: Info - Node: 130 Sending (Send) message (Callback ID=0x02, Expected Reply=0x13) - Nonce_Get(UserCodeCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x82, 0x02, 0x98, 0x40, 0x05, 0x02:
[20201231 3:48:27.868 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:48:27.868 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:48:29.179 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:48:29.180 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:48:29.214 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x00, 0xe9
[20201231 3:48:29.215 UTC] [ozw.library] [critical]: Error - Node: 130 ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
[20201231 3:48:30.351 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x01, 0x00, 0xe8
[20201231 3:48:30.352 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
[20201231 3:48:30.352 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 2493 Average Request RTT 1312
[20201231 3:48:30.499 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x01, 0x00, 0xe8
[20201231 3:48:30.500 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
[20201231 3:48:30.500 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 2641 Average Request RTT 1976
[20201231 3:48:30.625 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:48:30.626 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:48:30.662 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x01, 0x00, 0xe8
[20201231 3:48:30.663 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
[20201231 3:48:30.663 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 2804 Average Request RTT 2390
[20201231 3:48:30.846 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x82, 0x0a, 0x98, 0x80, 0xc6, 0xdd, 0xdf, 0x49, 0x78, 0xe0, 0x97, 0xa7, 0x5e
[20201231 3:48:30.846 UTC] [ozw.library] [info]: Info - Node: 130 Received SecurityCmd_NonceReport from node 130
[20201231 3:48:30.847 UTC] [ozw.library] [info]: Info - Node: 130 Encrypted Flag is 1
[20201231 3:48:30.847 UTC] [ozw.library] [info]: Info - Node: 130 Sending (Send) message (Callback ID=0x66, Expected Reply=0x13) - UserCodeCmd_Set (Node=130): 0x01, 0x0f, 0x00, 0x13, 0x82, 0x08, 0x63, 0x01, 0x01, 0x01, 0x31, 0x32, 0x33, 0x34, 0x25, 0x66, 0x4c
[20201231 3:48:30.858 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:48:30.858 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
So now we’ll clear the code
[20201231 3:49:50.912 UTC] [ozw.library] [info]: Info - Node: 130 Value::Set - COMMAND_CLASS_USER_CODE - Remove User Code - 256 - 1 - 1
[20201231 3:49:50.914 UTC] [ozw.library] [debug]: Detail - Node: 130 Setting Encryption Flag on Message For Command Class COMMAND_CLASS_USER_CODE
[20201231 3:49:50.915 UTC] [ozw.library] [debug]: Detail - Node: 130 Queuing (Send) UserCodeCmd_Set (Node=130): 0x01, 0x0f, 0x00, 0x13, 0x82, 0x08, 0x63, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x25, 0x73, 0x5c
[20201231 3:49:50.916 UTC] [ozw.library] [debug]: Detail - Node: 130 Setting Encryption Flag on Message For Command Class COMMAND_CLASS_USER_CODE
[20201231 3:49:50.917 UTC] [ozw.library] [debug]: Detail - Node: 130 Queuing (Send) UserCodeCmd_Get (Node=130): 0x01, 0x0a, 0x00, 0x13, 0x82, 0x03, 0x63, 0x02, 0x01, 0x25, 0x74, 0x56
[20201231 3:49:50.917 UTC] [ozw.library] [info]: Info - Node: 130 Processing (Send) Nonce Request message (Callback ID=0x73, Expected Reply=0x13)
[20201231 3:49:50.919 UTC] [ozw.library] [info]: Info - Node: 130 Sending (Send) message (Callback ID=0x02, Expected Reply=0x13) - Nonce_Get(UserCodeCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x82, 0x02, 0x98, 0x40, 0x05, 0x02:
[20201231 3:49:50.925 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:49:50.926 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:49:52.365 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x02, 0x00, 0xeb
[20201231 3:49:52.366 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
[20201231 3:49:52.367 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 1448 Average Request RTT 1503
[20201231 3:49:52.447 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x82, 0x0a, 0x98, 0x80, 0x33, 0x18, 0xa0, 0x56, 0x4e, 0x51, 0x07, 0xfd, 0x43
[20201231 3:49:52.447 UTC] [ozw.library] [info]: Info - Node: 130 Received SecurityCmd_NonceReport from node 130
[20201231 3:49:52.448 UTC] [ozw.library] [info]: Info - Node: 130 Encrypted Flag is 1
[20201231 3:49:52.449 UTC] [ozw.library] [info]: Info - Node: 130 Sending (Send) message (Callback ID=0x75, Expected Reply=0x13) - UserCodeCmd_Set (Node=130): 0x01, 0x0f, 0x00, 0x13, 0x82, 0x08, 0x63, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x25, 0x75, 0x5a
[20201231 3:49:52.461 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:49:52.462 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:49:52.634 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x75, 0x00, 0x9c
[20201231 3:49:52.635 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x75 received (expected 0x75)
[20201231 3:49:52.636 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 1718 Average Request RTT 1610
[20201231 3:49:52.637 UTC] [ozw.library] [debug]: Detail - Node: 130   Expected callbackId was received
[20201231 3:49:52.638 UTC] [ozw.library] [debug]: Detail - Node: 130   Expected reply was received
[20201231 3:49:52.639 UTC] [ozw.library] [debug]: Detail - Node: 130   Message transaction complete
[20201231 3:49:52.639 UTC] [ozw.library] [debug]: Detail - Node: 130 Removing current message
[20201231 3:49:52.640 UTC] [ozw.library] [info]: Info - Node: 130 Processing (Send) Nonce Request message (Callback ID=0x74, Expected Reply=0x04)
[20201231 3:49:52.641 UTC] [ozw.library] [info]: Info - Node: 130 Sending (Send) message (Callback ID=0x02, Expected Reply=0x04) - Nonce_Get(UserCodeCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x82, 0x02, 0x98, 0x40, 0x05, 0x02:
[20201231 3:49:52.649 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:49:52.650 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:49:52.719 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x02, 0x00, 0xeb
[20201231 3:49:52.719 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
[20201231 3:49:52.720 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 78 Average Request RTT 844
[20201231 3:49:52.807 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x82, 0x0a, 0x98, 0x80, 0x3b, 0x62, 0x19, 0x11, 0x69, 0x79, 0x92, 0x7d, 0xd5
[20201231 3:49:52.808 UTC] [ozw.library] [info]: Info - Node: 130 Received SecurityCmd_NonceReport from node 130
[20201231 3:49:52.809 UTC] [ozw.library] [info]: Info - Node: 130 Encrypted Flag is 1
[20201231 3:49:52.809 UTC] [ozw.library] [info]: Info - Node: 130 Sending (Send) message (Callback ID=0x76, Expected Reply=0x04) - UserCodeCmd_Get (Node=130): 0x01, 0x0a, 0x00, 0x13, 0x82, 0x03, 0x63, 0x02, 0x01, 0x25, 0x76, 0x54
[20201231 3:49:52.821 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:49:52.822 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:49:53.022 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x76, 0x00, 0x9f
[20201231 3:49:53.023 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x76 received (expected 0x76)
[20201231 3:49:53.024 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 382 Average Request RTT 613
[20201231 3:49:53.024 UTC] [ozw.library] [debug]: Detail - Node: 130   Expected callbackId was received
[20201231 3:49:53.447 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x82, 0x02, 0x98, 0x40, 0xab
[20201231 3:49:53.448 UTC] [ozw.library] [info]: Info - Node: 130 Received SecurityCmd_NonceGet from node 130
[20201231 3:49:53.455 UTC] [ozw.library] [info]: Info - Node: 130 Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x82, 0x0a, 0x98, 0x80, 0xc7, 0x59, 0xc5, 0xd7, 0x90, 0xf0, 0x93, 0x83, 0x05, 0x01, 0x95:
[20201231 3:49:53.466 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:49:53.467 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:49:53.603 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x01, 0x00, 0xe8
[20201231 3:49:53.603 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
[20201231 3:49:53.604 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 963 Average Request RTT 788
[20201231 3:49:53.702 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x24, 0x00, 0x04, 0x00, 0x82, 0x1e, 0x98, 0x81, 0x3c, 0xcc, 0xed, 0xb2, 0x57, 0xa5, 0xab, 0x68, 0x5e, 0xd3, 0x4a, 0xa9, 0xa3, 0x55, 0x47, 0x34, 0x7e, 0x2a, 0x89, 0xc7, 0xa2, 0xfc, 0x40, 0x60, 0x42, 0x00, 0xdd, 0x1e, 0xca
[20201231 3:49:53.703 UTC] [ozw.library] [debug]: Detail - Node: 130 Decrypted Packet: 0x00, 0x71, 0x05, 0x21, 0x01, 0x00, 0xff, 0x06, 0x0d, 0x00, 0x00
[20201231 3:49:53.704 UTC] [ozw.library] [info]: Info - Node: 130 Response RTT 1061 Average Response RTT 916
[20201231 3:49:53.704 UTC] [ozw.library] [info]: Info - Node: 130 Got a AlarmCmd_Report Message....
[20201231 3:49:53.705 UTC] [ozw.library] [info]: Info - Node: 130 Received Notification report (>v1): Type: Access Control (6) Event: Single User Code Deleted (13) Status: true, Param Length: 0
[20201231 3:49:53.705 UTC] [ozw.library] [debug]: Detail - Node: 130 Initial read of value
[20201231 3:49:53.706 UTC] [ozw.library] [debug]: Debug - Node: 130 Requesting Refresh of Value: CommandClass: COMMAND_CLASS_DOOR_LOCK Instance 1, Index 1
[20201231 3:49:53.706 UTC] [ozw.library] [debug]: Detail - Node: 130 Setting Encryption Flag on Message For Command Class COMMAND_CLASS_DOOR_LOCK
[20201231 3:49:53.707 UTC] [ozw.library] [debug]: Detail - Node: 130 Queuing (Send) DoorLockCmd_Get (Node=130): 0x01, 0x09, 0x00, 0x13, 0x82, 0x02, 0x62, 0x02, 0x25, 0x77, 0x57
[20201231 3:49:53.707 UTC] [ozw.library] [debug]: Detail - Node: 130 Notification: ValueChanged CC: COMMAND_CLASS_NOTIFICATION Instance: 1 Index: 6
[20201231 3:50:02.643 UTC] [ozw.library] [critical]: Error - Node: 130 ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "UserCodeCmd_Get (Node=130): 0x01, 0x0a, 0x00, 0x13, 0x82, 0x03, 0x63, 0x02, 0x01, 0x25, 0x76, 0x54"
[20201231 3:50:02.644 UTC] [ozw.library] [debug]: Detail - Node: 130 Removing current message
[20201231 3:50:02.644 UTC] [ozw.library] [debug]: Detail - Node: 130 Notification: Notification - TimeOut
[20201231 3:50:02.645 UTC] [ozw.library] [info]: Info - Node: 130 Processing (Send) Nonce Request message (Callback ID=0x77, Expected Reply=0x04)
[20201231 3:50:02.645 UTC] [ozw.library] [info]: Info - Node: 130 Sending (Send) message (Callback ID=0x02, Expected Reply=0x04) - Nonce_Get(DoorLockCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x82, 0x02, 0x98, 0x40, 0x05, 0x02:
[20201231 3:50:02.652 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:50:02.654 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:50:04.057 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x02, 0x00, 0xeb
[20201231 3:50:04.059 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
[20201231 3:50:04.060 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 1415 Average Request RTT 1101
[20201231 3:50:04.141 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x82, 0x0a, 0x98, 0x80, 0xc5, 0x58, 0x7e, 0x60, 0xd5, 0x67, 0xbe, 0x33, 0xc7
[20201231 3:50:04.142 UTC] [ozw.library] [info]: Info - Node: 130 Received SecurityCmd_NonceReport from node 130
[20201231 3:50:04.143 UTC] [ozw.library] [info]: Info - Node: 130 Encrypted Flag is 1
[20201231 3:50:04.144 UTC] [ozw.library] [info]: Info - Node: 130 Sending (Send) message (Callback ID=0x78, Expected Reply=0x04) - DoorLockCmd_Get (Node=130): 0x01, 0x09, 0x00, 0x13, 0x82, 0x02, 0x62, 0x02, 0x25, 0x78, 0x58
[20201231 3:50:04.155 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:50:04.156 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:50:04.445 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x78, 0x00, 0x91
[20201231 3:50:04.447 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x78 received (expected 0x78)
[20201231 3:50:04.448 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 1803 Average Request RTT 1452
[20201231 3:50:04.449 UTC] [ozw.library] [debug]: Detail - Node: 130   Expected callbackId was received
[20201231 3:50:04.749 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x82, 0x02, 0x98, 0x40, 0xab
[20201231 3:50:04.750 UTC] [ozw.library] [info]: Info - Node: 130 Received SecurityCmd_NonceGet from node 130
[20201231 3:50:04.757 UTC] [ozw.library] [info]: Info - Node: 130 Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x82, 0x0a, 0x98, 0x80, 0x50, 0xc7, 0xa3, 0x34, 0xdc, 0xdb, 0xf5, 0xf8, 0x05, 0x01, 0x63:
[20201231 3:50:04.767 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
[20201231 3:50:04.768 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA delivered to Z-Wave stack
[20201231 3:50:04.902 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x05, 0x00, 0x13, 0x01, 0x00, 0xe8
[20201231 3:50:04.903 UTC] [ozw.library] [debug]: Detail - Node: 130   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
[20201231 3:50:04.904 UTC] [ozw.library] [info]: Info - Node: 130 Request RTT 2258 Average Request RTT 1855
[20201231 3:50:05.003 UTC] [ozw.library] [debug]: Detail - Node: 130   Received: 0x01, 0x21, 0x00, 0x04, 0x00, 0x82, 0x1b, 0x98, 0x81, 0x49, 0x79, 0x27, 0x92, 0x4b, 0xb1, 0xb9, 0x64, 0xb8, 0x39, 0x84, 0x9f, 0x82, 0xda, 0xaa, 0xd9, 0x50, 0x1f, 0x25, 0xd9, 0xc4, 0x91, 0x21, 0xef, 0xff, 0x9e
[20201231 3:50:05.006 UTC] [ozw.library] [debug]: Detail - Node: 130 Decrypted Packet: 0x00, 0x62, 0x03, 0x00, 0x00, 0x02, 0xfe, 0xfe
[20201231 3:50:05.007 UTC] [ozw.library] [info]: Info - Node: 130 Response RTT 2362 Average Response RTT 1639
[20201231 3:50:05.008 UTC] [ozw.library] [info]: Info - Node: 130 Received DoorLock report: DoorLock is Unsecure
[20201231 3:50:05.009 UTC] [ozw.library] [debug]: Detail - Node: 130 Refreshed Value: old value=false, new value=false, type=bool
[20201231 3:50:05.009 UTC] [ozw.library] [debug]: Detail - Node: 130 Changes to this value are not verified
[20201231 3:50:05.010 UTC] [ozw.library] [debug]: Detail - Node: 130 Refreshed Value: old value=0, new value=0, type=list
[20201231 3:50:05.011 UTC] [ozw.library] [debug]: Detail - Node: 130 Changes to this value are not verified
[20201231 3:50:05.012 UTC] [ozw.library] [debug]: Detail - Node: 130   Expected reply and command class was received
[20201231 3:50:05.013 UTC] [ozw.library] [debug]: Detail - Node: 130   Message transaction complete
[20201231 3:50:05.014 UTC] [ozw.library] [debug]: Detail - Node: 130 Removing current message
[20201231 3:50:05.014 UTC] [ozw.library] [debug]: Detail - Node: 130 Notification: ValueChanged CC: COMMAND_CLASS_DOOR_LOCK Instance: 1 Index: 0
[20201231 3:50:05.015 UTC] [ozw.library] [debug]: Detail - Node: 130 Notification: ValueChanged CC: COMMAND_CLASS_DOOR_LOCK Instance: 1 Index: 1
But as you can see here the code is still in the slot
This has got me banging my head against a wall trying to figure it out. I hooked it up to SmartThings for a moment and I was able to add/remove user codes with that without issue but with OZW it just leaves the code behind. HA will log that it removed the code but it never does remove.
Says here the lock cleared the code.
This is where it fails to refresh for you.
So ultimately the lock does clear the code, it’s just ozw wasn’t able to refresh it because the command was dropped for some reason.
@firstof9 confirmed you are correct the code is indeed removed from the lock. Completed this test with the one sitting on my desk. I’ll await the next release of the lock-manager code. Should I file a issue with the OpenZwave folk about the codes not refreshing?
Feel free.
