YAML-configured button for dash that publishes 2 MQTT messages
I want to create a button that send 2 messages for 1 device. I know I can use Node-Red or automations. But I want to keep things as simple as possible so I was wondering if I can publish 2 MQTT messages with 1 button in the front end configured by YAML. I have looked around but found nothing.
I am not sure, if you can run/trigger an Action from a Template.
Then create an automation and add it to your dashboard. :slight_smile:
Or create a Script and add this to your dashboard.
This is a simple script, which closes our blinds to 66%.
There is an Automation, which triggers the script if certain conditions are true.
Sometimes, I would like to close the blinds manually, so I added the Automation and the scripts to my Dashboard. Simple and easy. :wink:
Thanks! For 1 MQTT message it’s even simpler than an automation, you can just add a button with some config. No automation needed MQTT button - Home Assistant
I was hoping it’s possible to add 2 MQTT messages there. Otherwise I will probably be using Node-Red for it.
It sounds as if what you want can be done by a “Template Button” helper entity which can be configured in the GUI, no YAML required.
ETA: the template integration docs imply this can be done in YAML if you really want to, but provides no examples which has led to some confusion on required syntax.
Thanks! I’ll give that a go.
Seems to do what I want it to, now to put this on a card as a custom button :slight_smile:
