YAML error I don't get resolved
I’m trying to create a button on a NSPanel which sets the setpoint of my thermostat 1 degree higher the the current setpoint. See code below.
But I get an error:
ERROR Error while reading config: Invalid YAML syntax:
mapping values are not allowed here
  in "/config/esphome/ns-panel.yaml", line 514, column 26:
                  temperature: "{{(state_attr('climate.nibe_1 ...
I don’t know what I’m doing wrong here.
Al help is more than welcome
- platform: nextion
    name: $device_name Thermostat up
    page_id: 6
    component_id: 9
    internal: true
    on_press:
      then:
        - homeassistant.service:
            service: climate.set_temperature
            entity_id: climate.nibe_126820_s1_room
              temperature: "{{(state_attr('climate.nibe_126820_s1_room' , 'temperature')|round(0)) + 1 }}"
try indenting entity_id: two more spaces under data:. Line it up with temperature:.
oehoe, stupid of me. Sometimes you stair at a problem without seeing the solution
Thanks for helping me out.
