Yaml insteon failsafe script
I have a automation setup to trigger a sequence of insteon lights. However I’m finding that sometimes even though the trigger occurs the lights do not turn on. What’s the recommended processed or scripting to add as a type of failsafe to check if the scene succeeded and if it didn’t to rerun the script until it does?
Post the automation.
BTW, change your post’s tag to “Configuration” (because it has nothing to do with “Share your Projects” or “Lovelace & Frontend”).
