As is often the case, the devil is in the excruciating detail.
YAML is a data serialisation language that normally uses a block structure to represent scalar (atomic data), sequences (lists/arrays) and mappings (dictionaries/objects).
This block-structure is extended to permit flow-structure, similar to JSON. Hence the ability to use [ ] and { }.
Whilst this is JSON-like it is not as strict as JSON. For a valid JSON object {"key": "value"} the key must be a string. The value can be an array/object as well as a valid primitive data constant. In YAML there are no quoted strings [at the basic level in block-style], and the mapping-key can be anything, including a sequence or mapping itself. Yes, the mapping key can be a mapping.
This means that {{test: one} : two } becomes a valid YAML mapping, taking the inner mapping {test: one} as the outer key. [yes, I tested this on YAMLlint and it is valid YAML...]
As Jinja templating is a string-substitution process, either the entire YAML is regarded as a "string" for parsing, looking for {{, or sub-sections of the YAML are regarded as "strings" and only these are passed for parsing. As {{ is valid YAML, the latter approach is required.
Since YAML does not use string quotation normally, the need and use of quotation is rather complicated, and varies between block-style and flow-style.
In the block-style, for scalar strings (string constants) there are the multi-line operators | [literal block scalar] and > [folded block scalar]. These mark what follows as strings.
For flow-style scalars, the single line string would normally be unquoted
- all good programmers should come to the party
Where special escaped characters are used, quoting the entire 'string' is required
- "the double quote \" needs to be escaped"
and this is the approach that has to be used on the single line, as a flow-style, so as to delimit "{{" as a string rather than valid YAML. Once the string has been passed to Jinja, it will return as a valid YAML and all is well.
In short - the difference in approach is entirely YAML, being the difference between a block-style scalar string (that needs no quotes to mark it as a string) and a flow-style scalar string, where (in this case) the 'string' holds invalid YAML. The block-style scalar string is seen as a string, whereas the flow-style scalar string is seen as YAML first and string second, and must be quoted to force to a scalar string.
Simple really.
YAML flow style
YAML quoting rules
The YAML parser, will see
day1: >
{{ this.attributes.get(iif(trigger.id=='start','day0','day1')) | float(0) }}
as a mapping, taking day1 as the key. The value is marked as a folded block scalar, which is a string over many lines. Since it is a string, YAML stops at this point. Inside HA, the 'string' will be passed to Jinja templating, which processes the bit inside {{ }} and returns a string value, which will be placed back into the YAML
Alternatively
attr1: {{ this.attributes.get('attr2') | float(0) }}
is seen also as a mapping, with attr1 as the key. However, this is flow-style and not block-style. YAML will now expect what follows to be a continuation of valid YAML that returns a value for the mapping key.
YAML sees { which is the start of a mapping in flow style, and commences to evaluate the mapping looking for a key.
{ is the start of a mapping, so the key is a mapping, which needs to be evaluated to look for a key.
is parsed to find the key: value before the closing mapping }. This will cause an error, either because there is no : or because | is a block style scalar command [you can't nest flow and block styles].
The YAML documentation has the explicit answer:-
When not to use Plain Scalars
Because a plain scalar without quotes can conflict with YAML syntax elements, there are some exceptions where you can not use it.
Characters that cannot be used at the beginning of a plain scalar:
- ! Tag like !!null
- & Anchor like &mapping_for_later_use
- Alias like *mapping_for_later_use
- - Block sequence entry
- : Block mapping entry
- ? Explicit mapping key
- {, }, [, ] Flow mapping or sequence
- , Flow Collection entry seperator
# Comment
- |, > Block Scalar
- @, ` (backtick) Reserved characters
- ", ' Double and single quote
<whitespace>
- % Directive
The single line is a plain scalar without quotes, and, as the documentation says, this can conflict with YAML syntax elements. And, there in the list, is {. Hence you can't start a plain scalar with {, let alone {{, and the answer is to quote the plain scalar.
