YAML / Lambda - If string is not empty
I created a Helper in HA - wash_person
In my ESPHome YAML program, I have a global string - laundry_person_wash
In my nested loop, I want to assign whatever/whomever is in my global string laundry_person_wash to my HA helper - wash_person. I can’t get my my second IF to work
     'return !id(laundry_person_wash).state.empty();'
This line keeps throwing an error.
/config/esphome/cyd-esp32.yaml: In lambda function:
/config/esphome/cyd-esp32.yaml:218:60: error: expected ';' before '}' token
  218 |                     'return !id(laundry_person_wash).state.empty();'
  219 |                 then:
/config/esphome/cyd-esp32.yaml:219:3: warning: no return statement in function returning non-void [-Wreturn-type]
  219 |                 then:
I also tried this (below) without the lambda, but that did not work either. This is what I tried before try Google’s recommendation above.
id(laundry_person_wash) != ""
Here is my full interval code
interval:
  - interval: 15s
    then:
      - if:
          condition:
            - lambda: |-
                return !id(recent_touch);
          then:
            - light.turn_off:
            - if:
                condition:     # id(laundry_person_wash) != ""
                  lambda:  |-
                then:
                  homeassistant.service:
                    service: input_text.wash_person #HELPER input_text in HA
                      value: id(laundry_person_wash) #Global string in ESPHome
            - lambda: |-
                id(bool_wash) = false;
                id(bool_dry) = false;
                id(laundry_person_wash) = "";
                id(laundry_person_dry) = "";
          else:
            - lambda: |-
                id(recent_touch) = false;
What is code that will work for me ?
I don’t even know this language, but what I can see is that you have quoted string for the lambda that is causing problems and in the remaining minds you don’t. Could that be relevant?
That makes two of us. About the only thing that i really know about YAML is it gets really picky with code alignment. 1 too many or too few TAB and the compiler gets mad.
I saw that as well with the quote. I did also try to compile my program without the ‘ ‘ only to get a different error
/config/esphome/cyd-esp32.yaml:218:44: error: ‘class std::__cxx11::basic_string’ has no member named ‘state’
218 | return !id(laundry_person_wash).state.empty();
In YAML, |-and >- is like adding implicit quoting.
Lambdas are C++ code.
So you are basically double-quoting your C++ code, which the compiler doesn’t understand.
2 choices:
  • keep the quotes, but remove line continuation:
lambda: 'return !id(laundry_person_wash).state.empty();'
  • Or keep the line continuation and remove the quotes:
lambda: |-
Both of those options result in the same error
/config/esphome/cyd-esp32.yaml:217:44: error: 'class std::__cxx11::basic_string<char>' has no member named 'state'
  217 |                   lambda: 'return !id(laundry_person_wash).state.empty();'
Further up is my global declaration
globals:
  - id: laundry_person_wash
    type: std::string
    initial_value: ''
    restore_value: no # Optional: saves value across reboots
Ah, you don’t need the .state part
This worked. Thanks so much!
