Iâve got the same problem here after upgrading to v0.117.0.
Documentation shows that the S1 Bulb, which has code name âcolor4â, is not in the Yeelight model list. I gues it needs to be added?
model string (optional)
Yeelight model. Possible values are mono1 , color1 , color2 , strip1 , bslamp1 , ceiling1 , ceiling2 , ceiling3 , ceiling4 , ceiling10 , ceiling13 . The setting is used to enable model specific features f.e. a particular color temperature range
Found that bug is in Yeelight firmware and not in Home Assistant
Even when controlling lights from telnet, at some point 1S models stop responding to messages until power cycle (older Yeelights working fine), they still accept commands from telnet and work, but not giving any response as if they were offline
So untill Yeelight wonât update firmware this probably wonât be solved
Iâm thinking switching to Tasmota bulbs but I got 6 Yeelights and donât want to waste them
