Hey everyone got a quick question. I recently setup a yeelight strip in my home assistant and everytime I reboot I get this error in my log.
I also a notice on my dashboard about component issue. I can just click dismiss on the message on the dashboard and everything works. I can control thr string light from HA and it is prsemted my google home no issues. Any thoughts? I had it assigned from my xioami gateway but it wasnt working right so I removes it and switched to the yeelight component. The fact everything works seems to point to a false error maybe?
2018-01-15 20:04:32 ERROR (MainThread) [homeassistant.config] Invalid config for [light.yeelight]: expected a dictionary for dictionary value @ data[‘devices’][‘192.168.0.116’]. Got None
expected a dictionary for dictionary value @ data[‘devices’][‘name’]. Got ‘Light Strip’. (See ?, line ?). Please check the docs at https://home-assistant.io/components/light.yeelight/
Sorry was on my phone and thought I sent it. Guess not. Will get it uploaded tonight. But a config issue would mean it should never work but it works fine.
Hey @Dominic. I had connected my yeelights to my xioami gateway as well as activated the yeelight component that is what was messing with mine. Although I have noticed recently I have both my string lights and the custom records for them showing up now. But I haven’t looked into why.
HA seems to be seeing the Yeelights as a native component so if you configure them as well it duplicates them. I don’t know if they are going to continue this way - if they do I guess we just ditch the custom component and use friendly_names
