Yeelight LED Filament not available
i’m currently on it to integrate my Yeelight LED Filament Blub into HA (https://www.yeelight.de/smart-led-filament-lampe.html). The Bulb + HA is on the latest version.
Currently i have the issue that the Bulb is reporting every 10-30min that its not available anymore. In this case there are two tricky scenarios:
  • When the Blub is active it gets shortly dark and lighten up again when connection is there again
  • In an automation the “dimming up” is interrupted and does not go on
does anyone of you have an idea how this can be solved?
