Since the new update something in the yeelight section is broken! It seems they are not syncing exactly anymore. My Lamps show me that the nightlight/moonlight is on even the lamp is off.
I downgraded back to 2021.8.5 and it worked perfectly again
To clarify: in the states “night_light:” its always true and so the binary sensor
I can deactivate it manually in the yeelight app but if i use the moonlight mode again i’m in a loop!The sensor/state stays on even if send command:
- service: light.turn_on
brightness: 255
color_temp: 250
(if i send this command it goes into moonlight mode again)
