Yellow with PI-5 - Update to 15.1/2 not working
Hello community!
I’m new to Home Assistant and recently bought a Yellow with a Pi-5 and SSD.
I currently have Home Assistant Operating System 15.0 installed, and it’s working perfectly.
Now 15.1 came along, and it wasn’t installed. I then looked into it and found the following:
There were several reports of intermittent upgrade problems on Raspberry Pi 5 (see #3943). Before you report an issue, try upgrading the EEPROM bootloader first, which resolved issues for the majority of users. To do so, the easiest way is to use a spare SD card with Raspberry Pi Imager and follow these instructions.
Unfortunately, I can’t figure out how to use the instructions for this Yellow with Pi-5 setup.
What should I do now?
Maybe one of you can help me?
The current version is 15.2, but that won’t install either…
Thanks and regards,
Christian
