YF-B10 moisture resistance
I would like to install YF-B10 sensor into access shaft to my underground rain water tank. It is closed very moisture area about 50 cm about the water surface.
But i know that water in these kind of areas can get in everywhere and make fatal damage for the electronics.
The space between the cables on the sensor does not seems to be well isolated. What do you think is it safe to place it there "as is " or should i try to make some kind of additional isolation ?
Is it anybody here with the experience of the sensor durability in the same kind of area ?
