I want to have a water valve shutoff when a leak is detected in my new home. The main water line is PVC with a ball valve 1". My original plan was to use the Zoozs titan on zwave but it doesn’t connect to a PVC ball valve and I would prefer to not have a plumber come to install a ball valve with a lever that is compatible.
My second choice would be the Yolink as it works with a PVC ball valve.
I have multiple Zoozs water sensor ZE42. Would I be able to create an automation that get the Yolink valve to close when the zoozs water leak sensors detected a leak? Any other positive or negative comments on the Yolink system?
This Aqara says it works on the butterfly-type handle. It doesn’t specify PVC that I could find and I couldn’t find any YouTube videos installing on PVC.
I would be nervous about using any type of valve controller on PVC though. Is there anywhere along the run that is brass? I was in same situation with a PVC ball valve on a 3/4" PVC line. I already owned the Dome Water Valve controller from previous house so I installed a Sharkbite Ball Valve in a portion of run that was brass. It’s super easy then you could definitely use the Aqara or similar and it would be cheaper than the Yolink.
