"You don't have any blueprints" while on local file it shows imported blueprints
automation mine: !include_dir_merge_list automations/
automation ui: !include automations.yaml
is included in config .
it does import the blueprints, but doesn’t show on the page nor i can use as automation…
Blueprints are keep in the blueprints folder
you have to import their first click on there My IMPORT BLUEPRINT
start looking here
that’s the problem , it is under the blueprints folder. imported like you said but doesn’t show up … that’s the problem i am facing…
Hi @hamsi12 , did you find a solution?
Iam facing the same problem: there are blueprints, i also used the import button. But i also get the message “You don’t have any blueprints” and i cant select them when creating a new automation.
My HA is running for 1 year now and i already used blueprints, so maybe its broken due to an update?
