Yr symbol empty. pls help
raw editor has this:
  - badges:
      - person.tung
      - sensor.date
      - sensor.time
      - sensor.yr_symbol
      - sensor.house2_keypad
      - sun.sun
config yaml has this:
  - platform: yr
any idea why i get an empty yr symbol as seen here?
What version of HA are you on ?
i swapped over from ubuntu virtual env with .9x and it was working fine. then, i changed to Proxmox running hassio Home Assistant 0.106.5. all of my yaml files were copied over to hassio config folder and everything seems fine with sensors except YR.
Yr changed their api. HA did a fix in 0.111.4 . If you still on an older version, there is not much you can do.
im happy to say upgrading to 0.111.4 fixed YR.
now looks like “device tracker” is broken. lol was working before i update
