Hi
Installed Z-Wave JS with Z-Stick Gen5+ (ZW090-C) but I cant connect or pair any devices.
I have a Z-Wave network already with Tellstick that I want to migrate to Z-Wave JS. I’ve tried with devices that has not been connected to the old Z-wave network and I’ve tried to exclude devices from the old and connect to Z-wave JS.
I should also notice that the USB-stick is blinking blue, yellow and red. I’ve read somewhere that this was normal but the sequence is not mentioned in the manual for the Z-wave.
Settings page
Drivrutin-version: 10.17.0
Serverversion: 1.28.0
Hem ID: [numbers]
Server-URL: ws://core-zwave-js:3000
only thing I find strange from the log is 2nd line, but how to fix?
Starting server on 0.0.0.0:3000
LOG:
2023-05-17T18:24:23.878Z DRIVER driver ready
2023-05-17T18:24:23.994Z CNTRLR [Node 001] The node is alive.
2023-05-17T18:24:23.999Z CNTRLR [Node 001] The node is ready to be used
2023-05-17T18:24:24.006Z CNTRLR All nodes are ready to be used
ZwaveJS server listening on 0.0.0.0:3000
New client
Client disconnected
Code 1000:
New client
2023-05-17T18:26:38.919Z CNTRLR Starting inclusion process with strategy Default...
2023-05-17T18:26:39.092Z SERIAL » 0x0105004ac10170 (7 bytes)
2023-05-17T18:26:39.106Z DRIVER » [REQ] [AddNodeToNetwork]
node type: Any
high power: true
network wide: true
callback id: 1
2023-05-17T18:26:39.134Z SERIAL « [ACK] (0x06)
2023-05-17T18:26:39.152Z SERIAL « 0x0107004a01010000b2 (9 bytes)
2023-05-17T18:26:39.162Z SERIAL » [ACK] (0x06)
2023-05-17T18:26:39.172Z DRIVER « [REQ] [AddNodeToNetwork]
status: Ready
callback id: 1
2023-05-17T18:26:39.227Z CNTRLR The controller is now ready to add nodes
2023-05-17T18:27:58.064Z CNTRLR stopping inclusion process...
2023-05-17T18:27:58.170Z SERIAL » 0x0105004ac50277 (7 bytes)
2023-05-17T18:27:58.175Z DRIVER » [REQ] [AddNodeToNetwork]
action: Stop
high power: true
network wide: true
callback id: 2
2023-05-17T18:27:58.203Z SERIAL « [ACK] (0x06)
2023-05-17T18:27:58.268Z SERIAL « 0x0107004a02060000b6 (9 bytes)
2023-05-17T18:27:58.276Z SERIAL » [ACK] (0x06)
2023-05-17T18:27:58.285Z DRIVER « [REQ] [AddNodeToNetwork]
status: Done
callback id: 2
2023-05-17T18:27:58.327Z CNTRLR The inclusion process was stopped
Client disconnected
Code 1000:
New client
New client
Client disconnected
Code 1000:
