Hello, everyone,
I’ve already read some things that others with Z-Wave in combination with “HASS.IO” have trouble installing! ->OK
I have read the hint -> https://www.home-assistant.io/docs/z-wave/controllers/ !
and the -> Razberry Board
You need to disable the on-board Bluetooth since the board requires the use of the hardware UART (and there’s only one on the Pi3). You do this by following the instructions in the -> device specific page
the first line is okay and done. -> dtoverlay=pi3-disable-bt
but the second expansion doesn’t work. -> $ sudo systemctl disable hciuart Error: unknown command „sudo“ for „hassio-cli“
Regards Jürgen
