z-Wave DOMEZBULB LED - unable to switch off
Folks,
I do use
Domitech ZBulb dimmbare LED Leuchte Z-Wave Plus DOMEZBULB and this appears in the Home Assistant GUI with the light switch but when I try to switch it off it flips back to on. The same happen when I try to dim. Any Idea? I is the Raspberry Pi All-In-One Installer (latest/yesteday) I do have a Aeotec USB Z-Stick S2 Adapter /Regler DSA02203-ZWEU - Z-Wave Plus and it shows as USB0
same issue here. Any hints how to solve it? Thanks!
Rgds
Looks like the LED is our of the range of my zwave stick of the my RapsberryPI. Is there a way/chance to check if the Raspberry PI Stick really reaches the zwave device? a zwave sniffer or detector :slight_smile:
Hi all, I can report the same issue
Only seems to be an issue with my dimmers (Aeotec DSC19103 Micro Smart Dimmer (2nd Edition)).
If i flick the device on manually then HA will realize its on in the GUI, but the GUI will not be able to turn it off, it will toggle off for a second and then back on.
– Same thing can be repeated with the device actually off and the GUI attempting to turn on.
Using OZW panel I can see the communication between HA and the node.
Mega weird results;
Lets say, start with Level 0.
Enter Level 85, submit - The level goes to ‘1’
Change level from 1 to 85, submit - The level goes to ‘85’
Dim, submit - The level goes to ‘82’
Dim, submit - The level goes to ‘80’
Bright, submit - No change in level
Bright, submit - The level goes to ‘99’
Dim, submit - No change in level
Dim, submit - The level goes to ‘0’
Enter Level 50, submit - The level goes to ‘1’
Enter Level 50, submit - The level goes to ‘50’
Enter Level 55, submit - The level goes to ‘51’
Enter Level 55, submit - The level goes to ‘55’
Enter Level 0, submit - The level goes to ‘54’
Enter Level 0, submit - The level goes to ‘0’
