Z-Wave – Dry contact + binary sensor in one
Good morning,
In the past there were some Z-Wave modules from Qubino, such as the Qubino 1D Relay. I still have three of them, and they allow the use of a dry contact relay while also connecting a magnetic sensor to work as a binary sensor.
Qubino was acquired by Shelly, and currently Shelly does not seem to have a single module that performs these two functions.
Does anyone know of a Z-Wave module with this capability?
Ths
Perhaps the Fibaro Implant might be an option for you.
Two dry contacts each for input and output, but instead of 230VAC it works with 9-30VDC.
The Zooz ZEN58 has a dry output and a dry input, but operates on 9-40VDC. They also have a number of other variants depending on your needs:
https://www.getzooz.com/smart-relays/
Thank you for your help :+1:.
I needed 230V :confused:
