Z-wave error: has unit of measure and device class enum
I’m getting this ominous error message in the core logs:
ValueError: sensor: sensor.outdoor_motion_sensor_manual_motion_re_trigger_time_setting has a unit of measurement and thus indicating it has a numeric value, it has the non-numeric device class: enum
The yaml from Settings–>Tools–>States
restored: true
options:
  - 5 seconds (Test mode)
device_class: enum
friendly_name: Currant House Outdoor Motion Sensor Manual Motion Re-Trigger Time Setting
supported_features: 0
unit_of_measurement: seconds
This was automatically created when I added the device.
Any idea what the problem is?
Yeah, it has a unit_of_measurement when it shouldn’t have that.
Your entity is coming through as a zwave list sensor
Which does not set unit_of_measurement at any point. If you have the option in the UI to remove or change the unit of measurement, change it to None.
I deleted it, disconnected it from z-wave, factory reset, restarted HA, restarted the virtual machine and otherwise spent a couple of hours thrashing. Eventually I got it connected again.
