Z-wave hub. Telldus live or vera?
I like Hass but never made the z-wave part as fast and stable as I’m used to. Therefor I want a z-wave hub. Has anyone experience in both the Vera and the telldus live v2 as a hub for HA?
Is there a delay when using any of these two devices? Seems to me that maybe the TellStick have more direct/faster communication?
Vera is a local component, Telldus is also local if you configure it with a local IP address. Both should be relatively responsive, though slightly slower than with a Z-Wave stick.
Ok thanks. Have you tried any of them yourself?
For me running the stick was pretty slow with raspberry pi 3 compared to indigo. But maybe faster on a NUC.
No, I run with the Razberry board on a Pi3, and it’s pretty snappy. Any lag issues I have are down to the Z-Wave mesh, not the Pi.
Using the OpenZwave from home assistant or a 3rd part?
OpenZWave, direct with HA
