Z-Wave is driving me crazy: two issues, naming and graphs
I got 2x Fibaro Motion Sensor and I added both of them as secure devices. This was working without issues. I can see both devices in home assistant.
Then I renamed the nodes in the Z-Wave Section of Home Assistant Frontend:
  1. One Sensor got the new name and all sensors were renamed
  2. The other sensor got also renamed, but all sensors stayed with the old name
The second issue I have is with the graphs. I added both temperature sensor to a group, but only one is shown as XY-Graph the other one only as a bar…
history_graph:
  dach:
    name: Temperatur Dachzimmer
    entities:
      - sensor.kinderzimmer_dominik_temperature
      - sensor.fibaro_system_fgms001zw5_motion_sensor_temperature
    hours_to_show: 72
    refresh: 300
_
group_Dachfenster:
default_view:
  view: yes
  entities:
    - group.group_Dachzimmer_Graphen
    - group.group_Dachfenster_All
    - group.group_Dachfenster_West
    - group.group_Dachfenster_Ost
    - group.group_Dachfenster_Mitte
    - group.group_Dachfenster_Automation
group_Dachzimmer_Graphen:
  name: Dachzimmer Temperatur
  view: no
  entities:
    - history_graph.temperatur_dachzimmer
One step ahead. Somehow the node entities in the Z-Wave config got now renamed, but the entities in Home-Assistant have still the old name…
For renaming zwave devices us this:
https://www.home-assistant.io/docs/configuration/entity-registry/
Just edit entity-registry.yaml and restart HA.
Add units I your temperature sensor to get it to show as a graph.
unit_of_measurement: C
Add that to customization or the configuration itself. With out it, the graph is treating the result as a string instead of a number, which is why you get the bar and not a graph
Thanks, I have done this now.
But I am still wondering, why that worked automatically for one sensor, but not for the other one…
Br,
Johannes
