Every time I update the Z-wave JS add-on; I have to fight to get my Aeotec Door/Window sensors to work again in Home Assistant.
I can open/close the sensors & see data updating in the Z-wave JS add-on logs but I do not see the sensor values updating in Home Assistant specifically.
It only affects 2 Aeotec Door/Window sensors; I have Aeotec plug switches that updating does not break & it also does not effect my ZCOMBOS ironically. Just the door sensors.
I am only using the Z-Wave JS Add-on; as of this moment I am not using Z-wave2mqtt. I was using that but I was having the same issue then so I switched to just using the JS add-on.
Z-Wave JS: Current version: 0.1.76
Home Assistant 2023.2.5
Supervisor 2023.01.1
Operating System 9.5
Frontend 20230202.0 - latest
