Z-Wave JS add-on options: not a valid value for dictionary value
Logger: homeassistant.components.zwave_js
Source: components/hassio/addon_manager.py:410
integration: Z-Wave (documentation, issues)
First occurred: January 19, 2025 at 1:15:47 PM (1046 occurrences)
Last logged: 12:26:14 PM
Failed to set the Z-Wave JS add-on options: not a valid value for dictionary value @ data[‘options’]. Got {‘device’: ‘/dev/serial/by-id/usb-0658_0200-if00’, ‘s0_legacy_key’: ‘REDACTED’, ‘s2_access_control_key’: ‘5AA0CF8D8AF498C5DACB6F90ED147F80’, ‘s2_authenticated_key’: ‘REDACTED’, ‘s2_unauthenticated_key’: 'REDACTED, ‘lr_s2_access_control_key’: ‘REDACTED’, ‘lr_s2_authenticated_key’: ‘REDACTED’}
I updated and the logs show this error
WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
I failing to start.
Any ideas on how to roll it back?
This is standard message if you use custom addons. It is for info only and does not indicate an error or good system operation
I would double check the entered data. You may be entering something wrong or extra
I’m going to take a guess and say that even though the config is correct, somehow the ZStick is not actually connected or seen by ZWaveJS
I started to have the same, not sure when:
2025-06-22 11:38:26.133 DEBUG (MainThread) [homeassistant.components.zwave_js] Add-on store info: {'detached': False, 'apparmor': 'default', 'auth_api': False, 'docker_api': False, 'full_access': False, 'homeassistant_api': False, 'host_network': False, 'host_pid': False, 'ingress': False, 'long_description': '# Home Assistant Add-on: Z-Wave JS\n\nAllow Home Assistant to talk to a Z-Wave Network via a USB Controller.\n\n![Supports aarch64 Architecture][aarch64-shield] ![Supports amd64 Architecture][amd64-shield] ![Supports armhf Architecture][armhf-shield] ![Supports armv7 Architecture][armv7-shield] ![Supports i386 Architecture][i386-shield]\n\n\n[aarch64-shield]: https://img.shields.io/badge/aarch64-yes-green.svg\n[amd64-shield]: https://img.shields.io/badge/amd64-yes-green.svg\n[armhf-shield]: https://img.shields.io/badge/armhf-yes-green.svg\n[armv7-shield]: https://img.shields.io/badge/armv7-yes-green.svg\n[i386-shield]: https://img.shields.io/badge/i386-yes-green.svg\n', 'rating': 6, 'signed': True, 'supervisor_api': True, 'supervisor_role': 'default', 'arch': ['amd64', 'i386', 'armhf', 'armv7', 'aarch64'], 'documentation': True, 'advanced': False, 'available': True, 'build': False, 'description': 'Control a Z-Wave network with Home Assistant Z-Wave JS', 'homeassistant': '2025.5.0', 'icon': True, 'logo': True, 'name': 'Z-Wave JS', 'repository': 'core', 'slug': 'core_zwave_js', 'stage': 'stable', 'update_available': False, 'url': 'https://github.com/home-assistant/addons/tree/master/zwave_js', 'version_latest': '0.16.0', 'version': '0.16.0', 'installed': True}
2025-06-22 11:38:26.137 ERROR (MainThread) [homeassistant.components.zwave_js] Failed to set the Z-Wave JS add-on options: not a valid value for dictionary value @ data['options']. Got {
'device': '/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0',
's0_legacy_key': 'REDACTED',
's2_access_control_key': 'REDACTED',
's2_authenticated_key': 'REDACTED',
 's2_unauthenticated_key': 'REDACTED',
'lr_s2_access_control_key': 'REDACTED',
'lr_s2_authenticated_key': 'REDACTED'
I did check that all the REDACTED valued are valid HEX and no invalid char had crept in. In this worked find. All I did was apply a recent upgrade
I found that my Z-WAVE JS add-on also is not starting:
2025-06-22 12:17:41.207 CONFIG   version 15.6.0
2025-06-22 12:17:41.596 CNTRLR   querying Serial API capabilities...
2025-06-22 12:17:46.555 DRIVER   Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
                                 from the controller (ZW0200)
                                     at Driver.sendMessage (file:///usr/src/node_modules/zwave-js/src/lib/drive
                                 r/Driver.ts:7057:23)
                                     at ZWaveController.queryCapabilities (file:///usr/src/node_modules/zwave-j
                                 s/src/lib/controller/Controller.ts:1063:37)
                                     at Driver.initializeControllerAndNodes (file:///usr/src/node_modules/zwave
                                 -js/src/lib/driver/Driver.ts:1970:46)
                                     at Immediate.<anonymous> (file:///usr/src/node_modules/zwave-js/src/lib/dr
                                 iver/Driver.ts:1696:16)
Error in driver ZWaveError: Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
    at Driver.sendMessage (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:7057:23)
    at ZWaveController.queryCapabilities (file:///usr/src/node_modules/zwave-js/src/lib/controller/Controller.ts:1063:37)
    at Driver.initializeControllerAndNodes (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1970:46)
    at Immediate.<anonymous> (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1696:16) (ZW0100)
    at Immediate.<anonymous> (file:///usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1716:6) {
  code: 100,
  context: undefined,
  transactionSource: undefined
Shutting down
[04:17:46] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
disconnecting the controller, and even fully shutting down my HA Rpi and restarting didn’t help
Your not mistakenly using both zwavejs and zwavejsui
Need to look into why it’s not connecting with controller
