Not sure if there are still issues but my previously rock solid Z-Wave network now has devices going dead randomly. Just updated Z-Wave JS to 0.1.64 and when I try to re-interview one of the dead nodes it looks like it reports back it didn’t respond to the ping. Right after that though I see the node (058) respond back, it’s like it’s not waiting long enough or aborting early
2022-06-25T22:01:40.616Z CNTRLR [Node 058] Beginning interview - last completed stage: None
2022-06-25T22:01:40.616Z CNTRLR [Node 058] new node, doing a full interview…
2022-06-25T22:01:40.618Z CNTRLR » [Node 058] querying protocol info…
2022-06-25T22:01:40.651Z CNTRLR « [Node 058] received response for protocol info:
basic device class: Routing Slave
generic device class: Binary Switch
specific device class: Binary Power Switch
node type: End Node
is always listening: true
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2022-06-25T22:01:40.653Z CNTRLR [Node 058] Interview stage completed: ProtocolInfo
2022-06-25T22:01:40.654Z CNTRLR » [Node 058] pinging the node…
2022-06-25T22:01:45.540Z CNTRLR [Node 058] The node did not respond after 1 attempts, it is presumed dead
2022-06-25T22:01:45.549Z CNTRLR [Node 058] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2022-06-25T22:01:45.550Z CNTRLR » [Node 058] querying node info…
2022-06-25T22:01:45.551Z CNTRLR » [Node 058] pinging the node…
2022-06-25T22:01:50.436Z CNTRLR [Node 058] The node did not respond after 1 attempts, it is presumed dead
2022-06-25T22:01:50.459Z CNTRLR [Node 058] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2022-06-25T22:01:50.460Z CNTRLR [Node 058] Interview attempt (1/5) failed, node is dead.
2022-06-25T22:03:16.561Z CNTRLR [Node 058] Beginning interview - last completed stage: None
2022-06-25T22:03:16.561Z CNTRLR [Node 058] new node, doing a full interview…
2022-06-25T22:03:16.563Z CNTRLR » [Node 058] querying protocol info…
2022-06-25T22:03:16.596Z CNTRLR « [Node 058] received response for protocol info:
node type: End Node
protocol version: 3
2022-06-25T22:03:16.599Z CNTRLR [Node 058] Interview stage completed: ProtocolInfo
2022-06-25T22:03:16.601Z CNTRLR » [Node 058] pinging the node…
2022-06-25T22:03:16.945Z CNTRLR [Node 058] The node is now alive.
2022-06-25T22:03:16.946Z CNTRLR [Node 058] Beginning interview - last completed stage: ProtocolInfo
2022-06-25T22:03:16.947Z CNTRLR » [Node 058] querying node info…
2022-06-25T22:03:16.962Z CNTRLR « [Node 058] ping successful
2022-06-25T22:03:16.962Z CNTRLR » [Node 058] querying node info…
2022-06-25T22:03:19.410Z CNTRLR « [Node 058] node info received
supported CCs:
· Z-Wave Plus Info
· Binary Switch
· Association
· Association Group Information
· Version
· Manufacturer Specific
· Node Naming and Location
· Device Reset Locally
· Powerlevel
controlled CCs:
2022-06-25T22:03:19.414Z CNTRLR [Node 058] Interview stage completed: NodeInfo
2022-06-25T22:03:19.416Z CNTRLR [Node 058] Interviewing Manufacturer Specific…
2022-06-25T22:03:19.417Z CNTRLR » [Node 058] querying manufacturer information…
2022-06-25T22:03:21.818Z CNTRLR [Node 058] Querying the node info failed
2022-06-25T22:03:21.819Z CNTRLR [Node 058] Interview attempt 2/5 failed, retrying in 10000 ms…
2022-06-25T22:03:24.233Z DRIVER no handlers registered!
2022-06-25T22:03:25.194Z CNTRLR « [Node 058] Received updated node info
2022-06-25T22:03:26.686Z CNTRLR [Node 058] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2022-06-25T22:03:28.400Z CNTRLR [Node 058] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2022-06-25T22:03:31.837Z CNTRLR [Node 058] Beginning interview - last completed stage: NodeInfo
2022-06-25T22:03:31.838Z CNTRLR [Node 058] Interviewing Manufacturer Specific…
2022-06-25T22:03:31.839Z CNTRLR » [Node 058] querying manufacturer information…
2022-06-25T22:03:38.814Z CNTRLR [Node 058] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2022-06-25T22:03:42.204Z CNTRLR « [Node 058] received response for manufacturer information:
manufacturer: EcoNet Controls (0x0157)
product type: 0x03
product id: 0x02
2022-06-25T22:03:42.220Z CNTRLR [Node 058] Interviewing Version…
2022-06-25T22:03:42.221Z CNTRLR » [Node 058] querying the CC version for Version…
2022-06-25T22:03:42.483Z CNTRLR [Node 058] supports CC Version (0x86) in version 2
2022-06-25T22:03:42.483Z CNTRLR » [Node 058] querying node versions…
