HI,
after 2024.12 update I’m getting this message
based on that I assume that i need to update the Z-Wave JS UI docker container
but I don’t see an update
I need to wait till the container update, right?
HI,
Your first screenshot implies you are using Z-Wave JS add-on, NOT Z-Wave JS UI as you have highlighted. Look at Settings > Add-ons and see if that Ad-on shows an update.
Edit - my mistake, yes you need an update of the container. Generally those are available when the core requirement is updated.
Considering your snap command, I’m guessing the last instruction is what applies instead of the line that you have highlighted.
I’m not a snap user, but the listing screenshot is pretty clear that you are tracking v9.19/stable
. So you should update to v9.26/stable
or v9.27/stable
channels. If you always want to be on the latest and greatest, then use latest/candidate
, but I always prefer being explicit about versioning (i.e. using Docker tags which is sort of equivalent).
Yep and that is what I’m trying to do
but it doesn’t pick the latest. It seems that I’m stuck on my version
Your command is wrong, the error message is telling you there’s no channel named =latest/stable
, which is true.
--channel=latest/stable
not --channel==latest/stable
Apparently --stable
is equivalent to --channel=latest/stable
, so if it didn’t switch at the point I don’t know why.
But you should also not use latest/stable
if using Home Assistant, it does not track HA requirements. Use either a specific version channel as I mentioned originally, or use latest/candidate
I got it
sudo snap refresh --stable zwave-js-ui
sudo snap refresh --channel=v9.27 zwave-js-ui
Thank you
