Z-Wave JS not defining all available entities for GC-TBZ48I
I’m new to Home Assistant and have just started to migrate my z-wave network from Homeseer to Home Assistant. When I add my GoControl GC-TBZ48 thermostat, z-Wave JS only builds 4 entities. They are,
sensor.first_floor_thermostat_air_temperature_2
sensor.first_floor_thermostat_battery_level_2
binary_sensor.first_floor_thermostat_low_battery_level_2
climate.first_floor_thermostat_thermostat_mode_2
I do not get any entities created for Heat Setpoint or Cool Setpoint. What am I missing? Any help would be greatly appreciated.
The climate entity is the entity that manages the setpoints, and setting the climate’s hvac mode and temperatures modifies the setpoints. They are not exposed externally.
So the climate entity’s will need to be called in either a custom automation or in a script. So if I use this in my automation.yaml file it will work.
Set First Floor temperature to 63 in heat mode for the Evening
  • id: “1613082972666”
    platform: time
    at: “09:45:00”
    • service: climate.set_temperature
      entity_id: climate.first_floor_thermostat_thermostat_mode2
      temperature: 63
      hvac_mode: heat
Set Second Floor temperature to 63 in heat mode for the Evening
  • id: “1613082972667”
    platform: time
    at: “09:45:00”
      entity_id: climate.second_floor_thermostat_thermostat_mode
      temperature: 63
      hvac_mode: heat
Is is okay to “make up” my own “id” numbers?
Thanks for your help as I work my way through this.
Judd
Looks reasonable, although the automation is not formatted so not sure if there are any syntax errors.
The service API is a little weird with zwave thermostats. If the thermostat is OFF, you might need to turn it on first with a call to service climate.set_hvac_mode and set to heat before setting temperature. You’ll have to experiment yourself to see if that’s true or not.
AFAIK, the ids are only used by the UI.
Thanks again. The formatting was due to my copy and paste. I do appreciate the help as I’m in the process of converting my automation from Homeseer to Home Assistant.
